Arctic Cooling T2 Silentium Silent Midi Tower Case - 450W Seasonic Silent PSU (CA-001
4 Jul 2005
UK
Anyone got this? Is the PSU any good?
Could it handle this:
I'm a little worried that 350W won't be enough for the X1800Xt.
Your spending a lot of money on a high end system, the PSU is the most important part of a PC.
£50+ for that system I would spend on the PSU alone. I really can not stress enough the importance of a good PSU, although it is a seasonic you are on the edge of what it could run, yet alone the peak the system could draw; especially if you overclock.
A Hiper PSU, or a Tagan of 480w+ would be a safer choice, and get the cheapest case possible.
Depends on how much money you have to play with on the Case + PSU bundle.
From what i remmeber, there's no way to fit a standard PSU into that case? You've got to use the one that comes with it.
