Arctic cooling T2
5 Jul 2005
Brighton
Just a quick check, title says 450w but the dscription says 350.
Just seeing which it is.
Oh, I need a decent looking case + PSU for about £60, other than the AC T2 i was thinking the Antec 3000b + FSP 400w PSU.
The original model was a 350W Seasonic, the latest ones are listed as 450W, but it's now 350W continuous, 450W peak. It's plenty though. Seasonic are excellent PSU's and they punch well above their weight.
Yeah I guessed that being seasonic and all, Just that it will have quite a bit to power (for a 350w psu) and the case needs to have decent cooling.
Spec in there will be a 3ghz prescott (478, first revision heat factory ;)), 2x512mb ram, 2x80gb HD, dvd burner, 6800NU etc.
Cheers for the help
That should be fine on a 350w quality psu.
I ran a similar system on a 350w Cheiftec psu (read: Antec) so the seasonic should be laughing.
Although I would buy the Antec case, as the Artic is just to flimsy for my liking.
Yeah was thinking the same, seen a 350w FSP that i will try to get (auction) and then buy the antec. The arctic is my back up plan :p
