Hi,
Yeah I use the F12 Pro's and as far as I know the "Pro" version are specifically for exhaust because of the way they are mounted. If you're looking for an intake version get the standard Arctic F12 and not the PRO edition as these can be mounted for intake or exhaust.![]()
What is the pressure rating on these fans? Any good for radiators?
+1
Dunno, but they're not terrible.
I'd rather get these and stick them on a fan controller if your mobo doesn't control 3pin. Could just use voltage reducers I s'pose.
I have two F12 PWM fans on my H80i and they work very well and are nice and quite.
I think we need to add price into the static pressure and noise to performance ratio equation. I'm sure the GT1850's are hand down better, but they are £14.98 and F12 PWM is £4.39.. Less than a third the price; 29% as much; £10.59 cheaper..
Being able to say "they work very well and are nice and quiet" for £4.39 is pretty amazing.
Will you be comparing them? If so please let us know how they compare.
Those of us who do not have either and need some good fans would find your knowledge useful.
But how do they compare to the legendary and super sexy GT 1850's? I just can't believe they would be better in terms of static pressure and noise to performance ratio. I know Arctic fans are good, the accelero fans taught me that.
