Arctic Freezer 13 High Performance CPU Cooler
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys
We have the first stock of the Freezer 13 in the UK. :)
Arctic Cooling Freezer 13 High Performance CPU Cooler (Socket LGA775/1156/1366/939/AM2/AM2+) @ £27.99 inc VAT
Following the footsteps of the renowned Freezer 7 Pro Rev.2., the Freezer 13 carries on the legacy of providing efficient and low noise CPU cooling solution for enthusiasts. Featuring a whisper-quiet 92 mm PWM fan, aluminum fins with heatpipes, the Freezer 13 can perform its duties with any high-performance CPU.
- Heatsink Dimension: 123mm x 96mm x 130mm (L x W x H)
- Heatsink Material: Aluminum fins x 45, thickness 0.5mm
- Fan: 92mm, 600 – 2000 RPM (controlled by PWM)
- Air Flow: 36.4 CFM
- Max. cooling capacity: 200 Watts
- Bearing type: Fluid Dynamic Bearing
- Weight: 695g
- Compatibility: Intel 775/1156/1366 AMD 939/AM2/AM2+/AM3
Only £27.99 inc VAT.
ORDER NOW
