According to its specs, the Kolink Stronghold should have space for a 160mm CPU cooler. Does anyone have an Arctic Freezer 34 (whether the cheap one, or the eSports or Duo, as they're all the same height)? It's specced as 157mm tall, so there *should* be 3mm clearance, but before I order one, it would be good to get confirmation. FWIW, it's to cool a stock R5 2600.
TIA!
TIA!
