As the major source of noise is now coming from my arctic freezer 64 fan, I was wondering whether it was possible to change the fan for something quieter, whilst still maintaining the flow rate, if not increasing it.
Would it be possible to fit an aftermarket, quieter fan to it eg. akasa amber of the same 92mm size? I see the fan is mounted on rubber mounts that simply push into the fan holes.
If it is possible, what size fan would it be, and has anyone done this before?
