Arctic Freezer 64 Pro Orientation on DFI Lanparty Sli-Dr?
4 Aug 2005
After changeing my motherboard i realised that the orientation of the freezer changes airflow, i was wandering if there is any way of orientating the freezer so that it pulls air from the front of the case and exits via my 120mm fan at the back? as this has raised my temps quite a bit
You can dismantle the retention clip (the bit you push down) with just one screw, pull the clip out, put it in the oter side. Replace screw and presto!
