Arctic Freezer 64 Pro
24 Oct 2005
North East
I got mine back in feb this year and it goes with my 3500+.
Most of the time since i have had it it has been acting weirdly. In pcprobe and everest the speed rated it reports says it is 2328. But every now and again its rating drops to 0 for about 5-10 seconds then goes back to normal for awhile. I have checked if its still spining the hsf and it is. But my worry is that it is not going to give accurate temperature results of the cpu if it is having problems with reporting correct speed constantly.
My gfx cooler never does this, nor does the akasa amber fan on front of the case.
If you use CoreTemp to measure your CPU temps, a dodgy fan reading shouldn't be a problem as it finds the temperature directly from a diode(?) in the CPU core.
