- 25 Nov 2010
- Lancashire
Arctic Freezer 7 Pro rev. 2 on a Gigabyte MA770-UD3 mobo:
The heatsink is tight up against the RAM module in slot 1 - so tight it's actually nudging it over by about a millimetre. Anyone else have this issue?
I installed it just now, and kept the pre-applied thermal compound on the base - if I now unscrew it to sort the RAM problem out, will it be okay to replace without getting new compound?
I'm guessing that my RAM will run okay if I use slots 3 and 4 instead of 1 and 2? (I checked the dual-channel pairings) - anybody have any advice?!
Thanks chaps...
Thanks chaps...
