Arctic Liquid Freezer* II Fan replacement
28 Feb 2021
My Arctic Liquid Freezer II 360mm RGB has picked up a rattle in one of the fans (seen it wobbling as well when it rattles) so I'm looking to replace the fan before the rattle drives me insane.
I believe it comes with P12 PWM PST A-RGB - or at least those look to be the most suitable compatible official replacement.
However as I've got to open the case up and fiddle with fans I wonder if there's any reason to consider upgrading the one fan or all 3 to a different brand/performance of fan? RGB isn't important to me (at the time it just so happened to be the cheaper of the setups or the only one I could buy at the time - I forget which). I could always put the two working 120mm fans on the bottom of my case for some extra air intake, so they wouldn't be wasted.
With the case I have I don't have room to mount a duel fan setup of push+pull so its really just the one side of fans to replace.
