Just fitted an E6750 and it has the stock horizontal fan cooler with a duct that extends down from a vent in the side of the case.
I'm not overclocking and I'm not having any problems with heat but it doesn't feel good engineering to me.
The ducting partly obstructs the rear fan and because the CPU fan is not vertical I get the feeling that there is not a lot of air movement around the memory.
I was thinking of replacing the stock cooler with an Artic Pro Freezer 7 - I guess it's a better cooler anyway but also it feels that air circulation inside the case would be better.
What do you think - improvement or waste of £20.
Cheers,
Nigel
Cheers,
Nigel
