- 18 Sep 2020
Hi people.
I am looking for some advice before I inadvertently cause irreperable damage!
I have a home-built computer which had an Asus Gryphon Z97 motherboard, and it was powered by a 19v DC external power block, feeding an internal HDPlex 160watt DC-ATX Converter.
The internal 24pin to 24pin cable from the DC Converter to the motherboard is very short. (10cm)
However, I have now bought an HDPlex 400w HiFi DC-ATX Converter to replace the 160 watt one, and I have to position it further away from the motherboard. I really need a cable of 45cms between the two.
I always thought that ATX cables would be fully interchangeable, but I have recently been told that pin-outs of both DC-ATX converter and of motherboards can be very different.
I would like to avoid using an extension cable, which are easily available. I would rather have a single, straight-through cable.
So can anyone tell me please: Do I need to supply a cable builder such as SHakmods, with pinouts of both the DC-ATX and the motherboard, and trust them to get it right, or can I just buy a 45cm one 'off the shelf'?
Thank you!
Thank you!
