As the title says, are the BitFenix Spectre Plain Black 120mm and 140mm fans controllable (RPM) . I am asking because on the specs it has a fixed RPM of 1000 (for the 120mm).
The rated rpm is usualy rated rpm when at 12 volts and a fan controler simply lowers the volts to the fan making it run slower.
Aslong as you are not running the fan on too low a volt it wont spin up you should be fine.
