Are brake lights compulsory?
28 Oct 2006
Sufferlandria
I've been restoring an old moped and now everything is back together and I just need to finish off the wiring. I've realised that there isnt a brake light.
Will it pass an mot? I'm pretty sure it came from the factory like this (I found a wiring diagram showing just a single wire running to the rear light and there doesnt appear to be any sort of switch/sensor in the brake levers either).
I know that cars can pass an mot without seatbelts and things if they were originally built like that. Is this a similar situation?
Yes it will pass,if they aren't originally on the bike then it will pass,same as no indicators on classic and vintage bikes as it was all hand signals back then
MOT Manual said:
Exemptions
If a stop lamp is fitted, it must meet the requirements of this inspection, but need not be fitted to a machine which:
a. cannot exceed 25mph, or
b. was first used before 1 January 1936, or
c. was first used before 1 April 1986 and which
has an engine capacity of less than 50cc.
So if it was first registered before April 1986 and is under 50cc you don't need a brake light.
you can use a little micro switch and a plate attached to the lever to make a switch or you can put a oil pressure switch into the brake circuit.
but iirc if you've got the light but it doesnt work its a fail if you've not got a lgiht at all (such as a trackbike) you can get an mot but it will be DAY TIME ONLY and if you ride when its dark you'll be guilty of dirving without an mot and without insurnace (as your insurance is dependant on your mot being vailid)
also its risky as **** mine broke while i was out and nearly got re soldered a few tiems before i relaised, resoldered it in a pub beer garden lol
Exactly, I've been behind a car recently that had no brake lights working and it took me a bit to relise he was actually stopping. Advantage of being on a bike is you can pull up next to them and tell them.
You expect motorbikes to have them so drivers would (subconsciously maybe) look for them.
if they arnt fitted when the bike was manufactured then you don't have to fit them,it will pass an mot
you can stick a lighthouse light on the back of your bike and still they wont see you
up to the owner to fit them or not,if you do fit them then they have to be working or they wont pass an mot,or take them off for the mot
Considering some people do this to people with a rear brake light, having nothing seems a bit risky to me.
Speaking as someone who did get shunted thusly, I wholeheartedly agree!!
Hand signals will be wasted on 90% of 2015 road users.
Strange how none of MY hand signals ever get misinterpreted... even stranger how they cannot see my indicator or brake lights, cannot hear my roaring engine, don't even notice me sat to the side and forward of them, yet always see the hand signals...
Yep there are some drivers that seem to be willfully ignorant, and its difficult to know who they are until its too late. But I'm not convinced there's no value to having a break light. Especially the flashing / blinking ones.
true,for some peace of mind id fit one,but for mot purposes you don't need to
they drive too close to you aswell,but tbf ive seen a fair few bikers tailgate cars,if ever they braked sharp they would hit
