- 24 May 2003
- UK
I am no longer within my 10 day training period and I know my line is around 5 km in length but even so does anyone else on Max DSL find that at peak times (mainly in the evenings from 6 PM onwards), eventually your connection drops due to a falling SN/R margin?
I don't expect this happens with short lines where I would guess that even with a full 8128 Kb sync there would still be enough spare SN/R margin to absorb any interference or crosstalk
What happens with me is that I sync at (say) 4.736 Mb in the morning and my connection is fine until the evening where the SN/R margin gradually drops until it reaches 3 dB and then I lose the connection.
When the router re-syncs it re-syncs at a slightly lower speed (4.512 Mb) and the same thing happens around 24 hours later.
It's a never ending cycle and has happened every day since I was on Max DSL.
It wouldn't be so bad if the sync speed came down over time and then was fixed at a speed that would allow enough SN/R margin to 'absorb' fluctuations in line noise level but this doesn't appear to be happening despite a BRAS line profile being used
I did try a SpeedTouch tool which initially worked as I set my SN/R to 9 dB but even with this tool when I came online this morning, the connection had dropped last night so I will either have to set the SN/R margin at an even higher level of 12 dB or just accept that my line will disconnect in around 24 hours time.
Anyone else experience this?
