I was thinking of getting led light strips for behind my tv. I have read a lot of reviews of them exploding. Is this a common fault ? If so are there any other options of tv lighting for the same cheap price ?
Wow, clearly you've never heard of the infamous LED riots of 1994 where a group of unattended LED strips wreaked havoc on the town of Denby-under-Water resulting in massive casualties and millions of pounds of property damage
Wow, clearly you've never heard of the infamous LED riots of 1994 where a group of unattended LED strips wreaked havoc on the town of Derby resulting in massive casualties and millions of pounds of Improvements
I have used LED strips in my place for 3 years , no explosions yet , but the cheaper power supplies have a habbit of dying , make sure it can deliver enough current
Yes its the cheap ones I'm talking about. I have herd a few review on amazon saying that the power supply from them has exploded and shot across the room. So can someone link me to some good quality ones because there seems to be a lot of crappy ones out there.
I've used the Antec ones and they seem like high quality products and as safe as anything like that will be.
I've seen some (not the Antec ones) melt before with the plastic going all brown but not heard of the strip itself catching fire/exploding though anecdotal stories of the cheap PSUs on knock offs malfunctioning.
I've also had some by silverstone that I was less than impressed with though they work ok and been using some outdoor/laptop ones by goalzero without any issues.
