- 5 Sep 2020
Mechanical keyboards are usually aimed at gamers but I'd like to know if mechanical keyboards are good for typing and general use?
Old school keyboards were heavier, more 'clicky', and with a longer travel than modern membrane keyboard. I don't know what the construction was, but presumably they were mechanical of some description.Actually they came over from professional typing to gaming i think didnt they?
I have MX Reds at home on a Steelseries Apex 7, which I use for work and gaming, and Blacks in the office.
Both work for me personally.
What's the difference betwen Blacks and Reds (they're both mechanical, right)?
https://www.mechanical-keyboard.org/switch-types/
It's down to wanting the feel of the keyboards, or the look of the keyboards, or the increased noise of using the keyboards (some want the loud click/hard key press noise). Last one may not be desirable for co-workers or co-habitants.
Of the switch types and if you're not concerned about noise I'd say blue and brown are your best bet, I find brown better than blue for gaming and a good middle ground for someone that does a lot of both on the same setup. The switch manufacturer comes into play here also, Cherry will feel a little different to Kailh for example.
I know Cherry have a good reputation. I take it Kaih is also a good brand?
This, although it was other people in my house who complained about the noise.I like the feel, but can't tolerate the noise
My wife is the same - we now share my office, courtesy of remote working, and she basically touch-punches the keyboard!I think I'd get murdered for using a mech keyboard at work. I'm heavy handed enough on soft membrane KBs
If you don't like the idea of making lot more noisey, forget MX Retro alias Blue and its clones/copies.And I should be looking for a Clicky preferably, or tactile switch with a longer actuation distance and higher actuation force.
Cherry MX switches were developed in early 80s and first marketed in 1985.Actually they came over from professional typing to gaming i think didnt they?
You're right - shorter hair, but watching with my eyes shut, it sounded like a very similar typing technique.At least this isn't your wife.
