15 Sep 2008 at 12:57 #1 sswats sswats Associate Joined 26 Mar 2004 Posts 1,199 I was asked to backup files off a laptop. windows is cocked so i couldn't log in, so i just plugged the HDD into another PC. I was asked to backup his MSN or windows live conversations? Any idea how to do that?
15 Sep 2008 at 12:58 #2 ConTRo13R ConTRo13R Soldato Joined 3 Mar 2008 Posts 3,147 Location Canterbury, Kent i think there is a log of them, i have pulled up a few before tho i cannot for the life of me remember where! but i know there is a log of them try looking thorugh the msn folders in 'program files'
15 Sep 2008 at 13:03 #3 Edward01 Edward01 Associate Joined 11 Mar 2007 Posts 1,741 Just had a look at my messanger and seems it doesn't save convo's by default unless you tell it to. But if you do the default location is as follows: C:\Documents and Settings\**User**\My Documents\My Received Files\**MSN User Name Plus random Numbers**\History
15 Sep 2008 at 13:43 #4 GarethDW GarethDW Soldato Joined 22 Jun 2006 Posts 2,971 Location Swindon Edward01 said: Just had a look at my messanger and seems it doesn't save convo's by default unless you tell it to. Click to expand... This is what I was about to say.
15 Sep 2008 at 13:43 #5 sswats sswats Associate OP Joined 26 Mar 2004 Posts 1,199 cool. found them. thanks
15 Sep 2008 at 13:48 #6 Simian Simian Soldato Joined 19 Oct 2002 Posts 8,075 Location Swindoniantown Ah.. Haa... Must look there when I get home!... most usefull!.
15 Sep 2008 at 16:12 #7 Greenlizard0 Greenlizard0 Man of Honour Joined 15 Mar 2004 Posts 28,140 Location Liverpool You can change the directory where it saves them too.
15 Sep 2008 at 16:12 #8 Toothy1911 Toothy1911 Associate Joined 27 Nov 2006 Posts 1,334 Location Coventry Messenger Plus! has a better chat logging function than standard, can come in real handy. Plus gives you a ton of other options/features
