Hi all,
Recently got myself a Raspberry Pi which is great, however, I am struggling with file transfers over my home network.
When I connect the Raspberry Pi to the upstairs switch which only has my computer on it (& Xbox) I can achieve file transfer speeds of 10.9MB/S.
If I connect the RPi downstairs I only get file transfer speeds of 5.1MB/s.
I am using ONE set of homeplugs that effectively connect the Virgin Media router and the switch together. So if I plug the RPi in downstairs the connection effectively has to go via the Homeplug set whereas if its connected upstairs it only has to go via the switch?
Am I correct in thinking that the homeplugs are somehow 'limiting' the transfer speed or is something else at work here?
Homeplugs are Devolo 500s (syncing at 300 on average).
Thanks all!
Thanks all!
