I have just received a corei7920 that has been OC'd to 3.2GHz.
It is running a 4870X2 and has been watercolled.
There is an ASUSP6T deluxeV2.
The problem I have is with the bios.
The memory is the G.SKILL PI series DDR31600MHz.
The timings on the modules state 8-8-8-21 but the bios is showing 9-9-9-24.
Does is need changed or do you think the company left them to increase stability in the OC?
Also the bios is showing QPI/DRAM CORE VOLTAGE 1.60000(in red) and
DRAM BUS VOLTAGE 1.70(in red).
Should these be lowered to get them out of the red?
And id so,what should I lower them to?
Thanks for all the help and replies.
