Are my temperatures ok ?
27 Jun 2008
Hello,
I was wondering if my case is cool enough. The machine has crashed a couple of times and when i have opened up the side of the case it seems pretty warm in there. Looking at the Catalyst control Centre software it says the temperature is 47% and fans are running at 60% this is temps whilst machine ticking over on desktop. I do not know if this is the case temperature or cpu temp etc? Any advice would be appreciated.
Specs Are
e8400 dual core cpu
ATI HD 5870 GPU
Gigabyte ep45-ds3 mobo
2x2gig overclockers memory
700 watt psu
Big heatsink and fan also on cpu
Get a program such as open hardware monitor, as this will tell you temps of most of the components in your case, then let us know what they are. Also, have you overclocked the GPU or CPU?
Hello,
Ok i downloaded hardware monitor and saved a report. I havent overclocked the pc. Are thesse temperatures ok? and I would like to add an extra fan to the front of machine but one that is really quiet any advice on this please.
+- Gigabyte EP45-DS3 (/mainboard)
| +- ITE IT8718F (/lpc/it8718f)
| | +- CPU VCore : 1.104 1.104 1.168 (/lpc/it8718f/voltage/0)
| | +- DRAM : 1.872 1.872 1.872 (/lpc/it8718f/voltage/1)
| | +- +3.3V : 3.312 3.312 3.312 (/lpc/it8718f/voltage/2)
| | +- +5V : 4.99968 4.9728 4.99968 (/lpc/it8718f/voltage/3)
| | +- Voltage #5 : 0.32 0.32 0.72 (/lpc/it8718f/voltage/4)
| | +- Voltage #6 : 0.016 0.016 0.096 (/lpc/it8718f/voltage/5)
| | +- Voltage #7 : 0.096 0.096 0.096 (/lpc/it8718f/voltage/6)
| | +- Voltage #8 : 3.024 3.024 3.024 (/lpc/it8718f/voltage/7)
| | +- VBat : 3.072 3.072 3.072 (/lpc/it8718f/voltage/8)
| | +- Temperature #1 : 41 41 42 (/lpc/it8718f/temperature/0)
| | +- Temperature #2 : 27 27 29 (/lpc/it8718f/temperature/1)
| | +- Fan #1 : 1207.51 1173.91 1259.33 (/lpc/it8718f/fan/0)
| | +- Fan #3 : 1088.71 1088.71 1092.23 (/lpc/it8718f/fan/2)
| | +- Fan #4 : 1062.99 1061.32 1068.04 (/lpc/it8718f/fan/3)
+- Intel Core 2 Duo E8400 (/intelcpu/0)
| +- Bus Speed : 333.321 333.321 333.321 (/intelcpu/0/clock/0)
| +- CPU Core #1 : 1999.93 1999.93 2999.89 (/intelcpu/0/clock/1)
| +- CPU Core #2 : 1999.93 1999.93 2999.89 (/intelcpu/0/clock/2)
| +- CPU Core #1 : 43 42 46 (/intelcpu/0/temperature/0)
| +- CPU Core #2 : 40 40 45 (/intelcpu/0/temperature/1)
| +- CPU Total : 1.538 0 51.2498 (/intelcpu/0/load/0)
| +- CPU Core #1 : 0 0 80.4999 (/intelcpu/0/load/1)
| +- CPU Core #2 : 3.07646 0 28.0326 (/intelcpu/0/load/2)
+- ATI Radeon HD 5800 Series (/atigpu/0)
| +- GPU Core : 1.05 1.05 1.1 (/atigpu/0/voltage/0)
| +- GPU Core : 157 157 600 (/atigpu/0/clock/0)
| +- GPU Memory : 300 300 900 (/atigpu/0/clock/1)
| +- GPU Core : 44.5 44 46.5 (/atigpu/0/temperature/0)
| +- GPU Core : 0 0 16 (/atigpu/0/load/0)
| +- GPU Fan : 1006 1005 1074 (/atigpu/0/fan/0)
| +- GPU Fan : 26 26 29 (/atigpu/0/control/0)
+- WDC WD6400AAKS-00A7B0 (/hdd/0)
| +- HDD : 34 34 34 (/hdd/0/temperature/0)
+- MAXTOR STM3200820AS (/hdd/1)
| +- HDD : 37 37 37 (/hdd/1/temperature/0)
Parameters
| | +- CPU VCore (/lpc/it8718f/voltage/0)
| | | +- Ri [kΩ] : 0 : 0
| | | +- Rf [kΩ] : 1 : 1
| | | +- Vf [V] : 0 : 0
| | +- DRAM (/lpc/it8718f/voltage/1)
| | | +- Ri [kΩ] : 0 : 0
| | | +- Rf [kΩ] : 1 : 1
| | | +- Vf [V] : 0 : 0
| | +- +3.3V (/lpc/it8718f/voltage/2)
| | | +- Ri [kΩ] : 0 : 0
| | | +- Rf [kΩ] : 1 : 1
| | | +- Vf [V] : 0 : 0
| | +- +5V (/lpc/it8718f/voltage/3)
| | | +- Ri [kΩ] : 6.8 : 6.8
| | | +- Rf [kΩ] : 10 : 10
| | | +- Vf [V] : 0 : 0
| | +- Voltage #5 (/lpc/it8718f/voltage/4)
| | | +- Ri [kΩ] : 0 : 0
| | | +- Rf [kΩ] : 1 : 1
| | | +- Vf [V] : 0 : 0
| | +- Voltage #6 (/lpc/it8718f/voltage/5)
| | | +- Ri [kΩ] : 0 : 0
| | | +- Rf [kΩ] : 1 : 1
| | | +- Vf [V] : 0 : 0
| | +- Voltage #7 (/lpc/it8718f/voltage/6)
| | | +- Ri [kΩ] : 0 : 0
| | | +- Rf [kΩ] : 1 : 1
| | | +- Vf [V] : 0 : 0
| | +- Voltage #8 (/lpc/it8718f/voltage/7)
| | | +- Ri [kΩ] : 0 : 0
| | | +- Rf [kΩ] : 1 : 1
| | | +- Vf [V] : 0 : 0
| | +- VBat (/lpc/it8718f/voltage/8)
| | | +- Ri [kΩ] : 0 : 0
| | | +- Rf [kΩ] : 1 : 1
| | | +- Vf [V] : 0 : 0
| | +- Temperature #1 (/lpc/it8718f/temperature/0)
| | | +- Offset [°C] : 0 : 0
| | +- Temperature #2 (/lpc/it8718f/temperature/1)
| +- CPU Core #1 (/intelcpu/0/temperature/0)
| | +- TjMax [°C] : 100 : 100
| | +- TSlope [°C] : 1 : 1
| +- CPU Core #2 (/intelcpu/0/temperature/1)
Mainboard
SMBIOS Version: 2.4
BIOS Vendor: Award Software International, Inc.
BIOS Version: F3
Mainboard Manufacturer: Gigabyte Technology Co., Ltd.
Mainboard Name: EP45-DS3
Mainboard Version: x.x
SMBIOS Table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==
LPC IT87XX
Chip ID: 0x8718
Chip Version: 0x5
Base Address: 0x0290
GPIO Address: 0x0800
Environment Controller Registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 13 10 00 00 FF FF 00 37 FF 87 54 09 17 2F FF 6C
10 FF FF FF 76 D7 FD FC FD 02 FF 02 FF FF FF FF FF
20 45 75 CF BA 14 01 06 BD C0 29 1C FE 80 3F C8 C8
30 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00
40 7F 7F 7F 7F 7F 7F 5F 74 2D 40 9C 22 FF FF FF FF
50 FF 2A 7F 7F 7F 50 F9 F9 90 F9 08 12 60 00 00 00
60 00 14 41 23 90 03 FF FF 00 14 41 23 90 03 FF FF
70 00 14 41 23 90 03 FF FF FF FF FF FF FF FF FF FF
80 7B 02 00 00 FF FF 00 00 00 00 00 00 00 00 02 00
90 FF 00 00 00 FF 00 00 00 FF FF FF FF FF FF FF FF
A0 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF
GPIO Registers
7E 3F 6B FA F6
CPUID
Processor 0
Processor Vendor: Intel
Processor Brand: Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz
Family: 0x6
Model: 0x17
Stepping: 0x6
CPUID Return Values
CPU Thread: 0
APIC ID: 0
Processor ID: 0
Core ID: 0
Thread ID: 0
Function EAX EBX ECX EDX
00000000 0000000A 756E6547 6C65746E 49656E69
00000001 00010676 00020800 0008E3FD BFEBFBFF
00000002 05B0B101 005657F0 00000000 2CB4304E
00000003 00000000 00000000 00000000 00000000
00000004 04000121 01C0003F 0000003F 00000001
00000005 00000040 00000040 00000003 00022220
00000006 00000001 00000002 00000001 00000000
00000007 00000000 00000000 00000000 00000000
00000008 00000400 00000000 00000000 00000000
00000009 00000000 00000000 00000000 00000000
0000000A 07280202 00000000 00000000 00000503
80000000 80000008 00000000 00000000 00000000
80000001 00000000 00000000 00000001 20100800
80000002 65746E49 2952286C 726F4320 4D542865
80000003 44203229 43206F75 20205550 45202020
80000004 30303438 20402020 30302E33 007A4847
80000005 00000000 00000000 00000000 00000000
80000006 00000000 00000000 18008040 00000000
80000007 00000000 00000000 00000000 00000000
80000008 00003024 00000000 00000000 00000000
CPU Thread: 1
APIC ID: 1
Processor ID: 0
Core ID: 1
Thread ID: 0
00000001 00010676 01020800 0008E3FD BFEBFBFF
Intel CPU
Name: Intel Core 2 Duo E8400
Number of Cores: 2
Threads per Core: 1
Timer Frequency: 2.929375 MHz
Time Stamp Counter: Not Invariant
Estimated Time Stamp Counter Frequency: 2999.89 MHz
Estimated Time Stamp Counter Frequency Error: 0.24578 Mhz
MSR Core #1
MSR EDX EAX
000000CE 001A0920 19190717
00000198 061A0920 06000920
0000019C 00000000 88380000
000001A2 00000000 00001600
MSR Core #2
MSR EDX EAX
Microarchitecture: Core
Time Stamp Counter Multiplier: 9
AMD Display Library
Status: OK
Number of adapters: 3
AdapterIndex: 0
isActive: 1
AdapterName: ATI Radeon HD 5800 Series
UDID: PCI_VEN_1002&DEV_6898&SUBSYS_E140174B&REV_00_4&3A258794&0&0008A
Present: 1
VendorID: 1002
BusNumber: 1
DeviceNumber: 0
FunctionNumber: 0
AdapterID: 0xA77240
AdapterIndex: 1
isActive: 0
UDID: PCI_VEN_1002&DEV_6898&SUBSYS_E140174B&REV_00_4&3A258794&0&0008&02A
Present: 1
VendorID: 1002
BusNumber: 1
DeviceNumber: 0
FunctionNumber: 0
AdapterID: 0xA77240
AdapterIndex: 2
isActive: 0
UDID: PCI_VEN_1002&DEV_6898&SUBSYS_E140174B&REV_00_4&3A258794&0&0008&03A
Present: 1
VendorID: 1002
BusNumber: 1
DeviceNumber: 0
FunctionNumber: 0
AdapterID: 0xA77240
What case do you have? How many fans and what size etc? What CPU Cooler are you using? Also if your planning an overclock what PSU?
It can be a right pain getting the right temps for an E8400 (You will find that Bios, RealTemp,Speedfan,HWmonitor etc all give different readings).
BUT!!!
They are great chips and with a little tweaking and a decent HSF you can hopefully get 4Ghz.
Hello again the case is a Zenith or something has a big Z badge on front. Couldn't work out how to upload a pic so i have uploaded 10 sec video to youtube of its insides. If anyone recognises the logo on the case fans i rem getting them cause the old ones were so noisy but these are really silent.
Arctic cooler freezer, which is facing the wrong way if the fan next to it is exhaust (pulling hot air from inside to outside) You need to face the fan on the cpu towards the front of the case
oh no,
Is my arctic cooler fan really the wrong way around. I thought it's fan near to the extractor one would expell the heat ?
as far as im aware, the arctic cooler brings in cold air and with the exhaust fan taking out the hot air, it will create a vacuum and push your temps up.
I couldn't see from the video whether you had any fans in the front of the case. If you do you should have them pulling air into the case, turn the Cooler around so it blows air towards the rear, then have the back fan blowing the air out of the back (most fans have little arrows to show air flow.
Once you have done that report back with some temp readings and we can see if we can get you overclocked.
Also, when you take the cooler off to move it around you will need to reapply some thermal compound (arctic silver etc) , really you should clean all of the old stuff off with some alcohol and a coffee filter.
ALSO, tidy those cables :P
On a more positive note you look like you have some fairly decent kit there including a decent PSU so overclocking really shouldn't be too much of an issue.
To add on to this, when you tide the cables, try and get them behind the motherboard plate because if you leave them in front of the fan when you turn it, the airflow from the front of the case to the fan will be blocked and you wont be pulling in much cold air.
Won't be long til you're overclocking that bad boy :p
Hello again,
Ok i have turned around the cpu cooler and tidied cables up. I have 2 fans in fron to machine sucking air in and one at the side. The back one which is in the video above is extracting the air. Here are the latest stats has anything improved greatly?
Open Hardware Monitor Report
Version: 0.3.2.0
Common Language Runtime: 4.0.30319.239
Operating System: Microsoft Windows NT 6.1.7601 Service Pack 1
Process Type: 64-Bit
Sensors
| | +- CPU VCore : 1.104 1.088 1.168 (/lpc/it8718f/voltage/0)
| | +- DRAM : 1.872 1.856 1.888 (/lpc/it8718f/voltage/1)
| | +- +3.3V : 3.312 3.312 3.328 (/lpc/it8718f/voltage/2)
| | +- +5V : 4.9728 4.9728 4.99968 (/lpc/it8718f/voltage/3)
| | +- Voltage #5 : 0.304 0.288 0.88 (/lpc/it8718f/voltage/4)
| | +- Voltage #6 : 0.016 0.016 0.128 (/lpc/it8718f/voltage/5)
| | +- Voltage #7 : 0.096 0.08 0.096 (/lpc/it8718f/voltage/6)
| | +- Voltage #8 : 2.928 2.912 2.944 (/lpc/it8718f/voltage/7)
| | +- Temperature #1 : 36 22 36 (/lpc/it8718f/temperature/0)
| | +- Temperature #2 : 26 14 34 (/lpc/it8718f/temperature/1)
| | +- Fan #1 : 1126.88 877.763 1412.13 (/lpc/it8718f/fan/0)
| | +- Fan #3 : 1069.73 992.647 1073.13 (/lpc/it8718f/fan/2)
| | +- Fan #4 : 1033.69 912.162 1035.28 (/lpc/it8718f/fan/3)
| +- Bus Speed : 333.302 333.302 333.302 (/intelcpu/0/clock/0)
| +- CPU Core #1 : 1999.81 1999.81 2999.71 (/intelcpu/0/clock/1)
| +- CPU Core #2 : 1999.81 1999.81 2999.71 (/intelcpu/0/clock/2)
| +- CPU Core #1 : 41 29 51 (/intelcpu/0/temperature/0)
| +- CPU Core #2 : 39 30 50 (/intelcpu/0/temperature/1)
| +- CPU Total : 3.84572 0 96.1538 (/intelcpu/0/load/0)
| +- CPU Core #1 : 3.07648 0 100 (/intelcpu/0/load/1)
| +- CPU Core #2 : 4.61494 0 92.3077 (/intelcpu/0/load/2)
| +- GPU Core : 1.1 1.1 1.2 (/atigpu/0/voltage/0)
| +- GPU Core : 400 400 850 (/atigpu/0/clock/0)
| +- GPU Memory : 1200 1200 1200 (/atigpu/0/clock/1)
| +- GPU Core : 52 35 54 (/atigpu/0/temperature/0)
| +- GPU Core : 0 0 39 (/atigpu/0/load/0)
| +- GPU Fan : 1139 814 1142 (/atigpu/0/fan/0)
| +- GPU Fan : 33 21 33 (/atigpu/0/control/0)
| +- HDD : 28 18 28 (/hdd/0/temperature/0)
| +- HDD : 31 19 31 (/hdd/1/temperature/0)
Parameters
| | | +- Ri [kΩ] : 0 : 0
| | | +- Rf [kΩ] : 1 : 1
| | | +- Vf [V] : 0 : 0
| | | +- Ri [kΩ] : 0 : 0
| | | +- Rf [kΩ] : 1 : 1
| | | +- Vf [V] : 0 : 0
| | | +- Ri [kΩ] : 0 : 0
| | | +- Rf [kΩ] : 1 : 1
| | | +- Vf [V] : 0 : 0
| | | +- Vf [V] : 0 : 0
| | | +- Ri [kΩ] : 0 : 0
| | | +- Rf [kΩ] : 1 : 1
| | | +- Vf [V] : 0 : 0
| | | +- Ri [kΩ] : 0 : 0
| | | +- Rf [kΩ] : 1 : 1
| | | +- Vf [V] : 0 : 0
| | | +- Ri [kΩ] : 0 : 0
| | | +- Rf [kΩ] : 1 : 1
| | | +- Vf [V] : 0 : 0
| | | +- Ri [kΩ] : 0 : 0
| | | +- Rf [kΩ] : 1 : 1
| | | +- Vf [V] : 0 : 0
| | | +- Ri [kΩ] : 0 : 0
| | | +- Rf [kΩ] : 1 : 1
| | | +- Vf [V] : 0 : 0
Mainboard
SMBIOS Version: 2.4
BIOS Version: F3
SMBIOS Table
LPC IT87XX
Chip ID: 0x8718
Chip Version: 0x5
00 13 10 20 00 FF FF 00 37 FF 87 54 09 17 57 FF 76
20 48 75 CF B9 1E 01 06 B8 C0 24 1A FE 80 FC 08 08
80 8D 02 00 00 FF FF 00 00 00 00 00 00 00 00 02 00
GPIO Registers
7E 1F 2B FA F6
CPUID
Processor 0
Family: 0x6
Model: 0x17
Stepping: 0x6
CPUID Return Values
CPU Thread: 0
APIC ID: 0
Processor ID: 0
Core ID: 0
Thread ID: 0
CPU Thread: 1
APIC ID: 1
Processor ID: 0
Core ID: 1
Thread ID: 0
Intel CPU
Number of Cores: 2
Threads per Core: 1
Estimated Time Stamp Counter Frequency: 2999.71 MHz
Estimated Time Stamp Counter Frequency Error: 0.04096 Mhz
MSR Core #1
MSR EDX EAX
0000019C 00000000 883A0000
MSR Core #2
MSR EDX EAX
0000019C 00000000 883C0000
AMD Display Library
Status: OK
AdapterIndex: 0
isActive: 1
Present: 1
VendorID: 1002
BusNumber: 1
DeviceNumber: 0
FunctionNumber: 0
AdapterID: 0xB2E140
AdapterIndex: 1
isActive: 0
Present: 1
VendorID: 1002
BusNumber: 1
DeviceNumber: 0
FunctionNumber: 0
AdapterID: 0xB2E140
AdapterIndex: 2
isActive: 0
Present: 1
VendorID: 1002
BusNumber: 1
DeviceNumber: 0
FunctionNumber: 0
AdapterID: 0xB2E140
S.M.A.R.T Data
Drive name: WDC WD6400AAKS-00A7B0
ID RawValue WorstValue AttrValue
1 00 00 00 00 00 00 200 200
3 DD 14 00 00 00 00 143 153
4 3C 05 00 00 00 00 99 99
5 00 00 00 00 00 00 200 200
7 00 00 00 00 00 00 200 200
9 2F 08 00 00 00 00 98 98
10 00 00 00 00 00 00 100 100
11 00 00 00 00 00 00 100 100
12 C8 02 00 00 00 00 100 100
192 77 00 00 00 00 00 200 200
193 3C 05 00 00 00 00 200 200
194 1C 00 00 00 00 00 81 119
196 00 00 00 00 00 00 200 200
197 00 00 00 00 00 00 200 200
198 00 00 00 00 00 00 200 200
199 00 00 00 00 00 00 200 200
200 00 00 00 00 00 00 200 200
132 7B 03 00 01 00 02 1 45
5 00 00 00 00 00 00 0 0
1 00 00 00 00 00 00 0 0
Drive name: MAXTOR STM3200820AS
1 56 57 BA 09 00 00 88 117
3 00 00 00 00 00 00 95 95
4 D3 07 00 00 00 00 99 99
5 00 00 00 00 00 00 100 100
7 0F 58 31 13 05 00 60 77
9 B1 19 00 00 00 00 93 93
12 66 08 00 00 00 00 98 98
187 00 00 00 00 00 00 100 100
189 00 00 00 00 00 00 100 100
190 1F 00 12 1F 6B 00 30 69
194 1F 00 00 00 0B 00 70 31
195 3D 0A 9E 09 00 00 61 101
197 00 00 00 00 00 00 100 100
198 00 00 00 00 00 00 100 100
199 01 00 00 00 00 00 200 200
200 00 00 00 00 00 00 253 100
202 00 00 00 00 00 00 253 100
130 5B 03 00 01 00 01 0 1
2 00 00 00 00 00 00 0 0
5 00 00 00 00 01 A5 0 0
45 00 01 00 06 D7 5A 0 0
54 00 00 00 00 00 00 0 0
62 00 00 00 03 75 00 3 119
I would suggest your next step be to download prime95 aswell as a few other temp monitoring tools. Speedfan and realtemp etc
Run prime 95 with each of the temp tools. Then we can get a better idea of temps. After all idle temps Like the ones you have posted are fairly pointless.
Ok i have run hardware monitor with Prime95 at 100%load the cpu cores are getting up to 57c is this good. Also can you check whats what with the readout below looks like gobbldy gook to me :)
Version: 0.3.2.0
Sensors
| | +- CPU VCore : 1.152 1.152 1.168 (/lpc/it8718f/voltage/0)
| | +- DRAM : 1.872 1.84 1.872 (/lpc/it8718f/voltage/1)
| | +- +5V : 4.9728 4.9728 4.9728 (/lpc/it8718f/voltage/3)
| | +- Voltage #5 : 1.104 0.784 1.136 (/lpc/it8718f/voltage/4)
| | +- Voltage #6 : 0.176 0.096 0.176 (/lpc/it8718f/voltage/5)
| | +- Voltage #8 : 2.928 2.928 2.944 (/lpc/it8718f/voltage/7)
| | +- Temperature #1 : 38 38 39 (/lpc/it8718f/temperature/0)
| | +- Temperature #2 : 44 39 46 (/lpc/it8718f/temperature/1)
| | +- Fan #1 : 2070.55 1896.07 2198.7 (/lpc/it8718f/fan/0)
| | +- Fan #3 : 1083.47 1080 1085.21 (/lpc/it8718f/fan/2)
| | +- Fan #4 : 1046.51 1044.89 1053.04 (/lpc/it8718f/fan/3)
| +- Bus Speed : 333.353 333.353 333.353 (/intelcpu/0/clock/0)
| +- CPU Core #1 : 3000.18 3000.18 3000.18 (/intelcpu/0/clock/1)
| +- CPU Core #2 : 3000.18 3000.18 3000.18 (/intelcpu/0/clock/2)
| +- CPU Core #1 : 57 53 58 (/intelcpu/0/temperature/0)
| +- CPU Core #2 : 56 51 57 (/intelcpu/0/temperature/1)
| +- CPU Total : 100 100 100 (/intelcpu/0/load/0)
| +- CPU Core #1 : 100 100 100 (/intelcpu/0/load/1)
| +- CPU Core #2 : 100 100 100 (/intelcpu/0/load/2)
| +- GPU Core : 52.5 52 53.5 (/atigpu/0/temperature/0)
| +- GPU Core : 0 0 3 (/atigpu/0/load/0)
| +- GPU Fan : 1154 1149 1159 (/atigpu/0/fan/0)
| +- GPU Fan : 33 33 33 (/atigpu/0/control/0)
| +- HDD : 31 31 31 (/hdd/0/temperature/0)
| +- HDD : 35 35 35 (/hdd/1/temperature/0)
Parameters
| | | +- Ri [kΩ] : 0 : 0
| | | +- Rf [kΩ] : 1 : 1
| | | +- Vf [V] : 0 : 0
| | | +- Ri [kΩ] : 0 : 0
| | | +- Rf [kΩ] : 1 : 1
| | | +- Vf [V] : 0 : 0
| | | +- Ri [kΩ] : 0 : 0
| | | +- Rf [kΩ] : 1 : 1
| | | +- Vf [V] : 0 : 0
| | | +- Vf [V] : 0 : 0
| | | +- Ri [kΩ] : 0 : 0
| | | +- Rf [kΩ] : 1 : 1
| | | +- Vf [V] : 0 : 0
| | | +- Ri [kΩ] : 0 : 0
| | | +- Rf [kΩ] : 1 : 1
| | | +- Vf [V] : 0 : 0
| | | +- Ri [kΩ] : 0 : 0
| | | +- Rf [kΩ] : 1 : 1
| | | +- Vf [V] : 0 : 0
| | | +- Ri [kΩ] : 0 : 0
| | | +- Rf [kΩ] : 1 : 1
| | | +- Vf [V] : 0 : 0
| | | +- Ri [kΩ] : 0 : 0
| | | +- Rf [kΩ] : 1 : 1
| | | +- Vf [V] : 0 : 0
Mainboard
SMBIOS Version: 2.4
BIOS Version: F3
SMBIOS Table
LPC IT87XX
Chip ID: 0x8718
Chip Version: 0x5
00 13 10 00 00 FF FF 00 37 FF 87 54 09 17 46 FF 70
10 FF FF FF 76 D7 FD FC FD 01 FF 02 FF FF FF FF FF
20 48 75 CF B9 45 0B 06 B7 C0 26 2C FE 80 F8 CA CA
80 84 02 00 00 FF FF 00 00 00 00 00 00 00 00 02 00
GPIO Registers
7E 3F EB FA F4
CPUID
Processor 0
Family: 0x6
Model: 0x17
Stepping: 0x6
CPUID Return Values
CPU Thread: 0
APIC ID: 0
Processor ID: 0
Core ID: 0
Thread ID: 0
CPU Thread: 1
APIC ID: 1
Processor ID: 0
Core ID: 1
Thread ID: 0
Intel CPU
Number of Cores: 2
Threads per Core: 1
Estimated Time Stamp Counter Frequency: 3000.18 MHz
Estimated Time Stamp Counter Frequency Error: 0.69644 Mhz
MSR Core #1
MSR EDX EAX
0000019C 00000000 882B0000
MSR Core #2
MSR EDX EAX
0000019C 00000000 882E0000
AMD Display Library
Status: OK
AdapterIndex: 0
isActive: 1
Present: 1
VendorID: 1002
BusNumber: 1
DeviceNumber: 0
FunctionNumber: 0
AdapterID: 0xB2E140
AdapterIndex: 1
isActive: 0
Present: 1
VendorID: 1002
BusNumber: 1
DeviceNumber: 0
FunctionNumber: 0
AdapterID: 0xB2E140
AdapterIndex: 2
isActive: 0
Present: 1
VendorID: 1002
BusNumber: 1
DeviceNumber: 0
FunctionNumber: 0
AdapterID: 0xB2E140
S.M.A.R.T Data
7 00 00 00 00 00 00 253 100
9 31 08 00 00 00 00 98 98
194 1F 00 00 00 00 00 81 116
7 78 5B 31 13 05 00 60 77
9 B2 19 00 00 00 00 93 93
190 23 00 12 23 6B 00 30 65
194 23 00 00 00 0B 00 70 35
195 25 85 A0 09 00 00 61 99
45 00 01 00 17 91 0E 0 0
62 00 00 00 DB 8A 00 3 119
Everything is looking fine.
Now to start overclocking. Personally I would whack it up to 4ghz with 1.3 v and go from there but I'm a lazy overclocker. Your prob better to start with 3.2 at stock then increase it slowly from there remembering to stress test after every increase and keep an eye on the temps overclocking (more voltage Is the main culprit) means increased heat.
Sorry for the fairly vague rushed answer but I'm on the road on my phone. Will try and help more later.
