Hi,
I have an i5 2500K, it is NOT overclocked, it is cooled by a Gelid Tranquillo (can't remember whether I used the paste that came with the Gelid, or Arctic silver 5 but it is one of the two) and this is my first ever PC that I have built so I just wanted to ask here and see if my temps are OK
I am using core temp by the way
I was playing Metro 2033 and the max temp was core #2 at 66 degrees Celsius, the others were 58 and 59
Minimum temp since I turned the PC on was 26
And now I am using it just for web browsing, just finished installing a couple of programs and has been on for a couple of hours and the temps are currently ranging between 30 and 40 degrees Celsius, occasionally dropping to 29 for a second or so.
Is that normal?
Thanks in advance,
Is that normal?
Thanks in advance,
