Are my voltages ok?
9 Jun 2006
Hi, just installed an OCZ GameXStream 700W PSU and was wondering if the following voltages are ok.
This is when i have something CPU intensive, like folding@home or something running
Vcore: 1.26v
+3.3: 3.25v
+5:4.94v
12:12.30v
This is idle:
Vcore: 1.14(min), but around 1.17 avg
+3.3: 3.25v
+5:4.94v
12:12.30
They are all within ATX tolerances I believe, you have +-5% so it should be fine. However note that software readings aren't always that accurate, you need a multimeter usually to do it properly. If you find that there aren't any issues with your system then I wouldn't worry about it too much, no matter what the voltages say. :)
