"When is a crack legal then?"
The use of cracks is legal and supported when it is for personal use only. It's legal when you bought the original game in a legal store, but you want to back your game/program up. copying a game after buying it is something I really recommend to do... use the copy to play the game, but keep the original at some safe place. If you damage the copy, you can still use the original to make a new copy, and so you will still be able to play the game. And believe me, damaging or screwing up a CD is done faster than you think The name says it... a backup CD crack enables you to play the game with a back-up (copy) of it, so that the chances that you damage YOUR original are reduced to the minimum. The purpose of a No-CD crack is the same as for backup CD cracks... reducing the chance to damage your original. No-CD cracks are also for people who don't want to switch CD's every time they want to play another game. It's also known that some games lag when they read the data from the (original) CD. In such case, a No-CD crack is a good solution, because you can play the game without the CD inserted if the crack was installed correctly.
Energize said:Why does the uk always have the most pointless laws, a simple patch that saves the effort of replacing cds made illegal![]()
Azagoth said:Frowned upon! We don't allow the discussion of said files on our forums, see sig, but if it's discussed via PM and such what can we do?
lowrider007 said:I can't believe it's illegal if you own the original software, I absolutely refuse to keep changing cd/dvd's everytime I want to play a game, otherwise it's like i,ve got a massive console, infact the way things are going at the moment I would'nt be suprised if in the future they work out a way to run games effectively like they do on consoles, straight off the disk and non-installable to your harddrive, infact i'm sure i've heard rumers of this as a possible way to help curb copyright infringement.
Ex-RoNiN said:Read the EULA. You're not allowed to modify code.
No-CDs do modify code.
Hence, off to prison you go![]()
Clearcut said:I'm sorry but that's hillarious. Someone with 312 posts making a statement like that to someone with 4700 posts - 'our forums'![]()
