on deaktop with the computer doing nothing apart from Everest running the cpu temps for core 1 and 2 are mid to high 40oc range and core 3 and 4 low 40oc range... but the other night i ran Prime95 for 10 min as i lost my bottle and stopped the test due to temps that the cores reached.. core 1 and 2 in prime cpu torture test peaked at 89oc! and core 3 and 4 were at high 70oc and low 80oc... are these tempreratures normal with my overclock setup? in my opinion they too high.. i might have not seated the heatsink properly on the cpu also i didnt get arctic 5 compound with my rig but a cheap one that came with the cpu cooler... also my case fans were all on full speed... do you think i should reseat the heatsink or get watercooling for the cpu... or am i paranoid and the temps are fine lol??? p.s in the 10 mins of prime95 test no errors were detected...
spec
*OVERCLOCKED* Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz @ 4.00GHz / Gigabyte EX58-UD5 Intel X58 Motherboard / Patriot Viper 6GB DDR3 PC3-12800C8 1600MHz DDR3 Bundle + World in Conflict Game
Gainward GeForce GTX 295 1792MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail
Corsair TX 750W ATX SLI Compliant Power Supply (CMPSU-750TXUK)
Antec 902 Nine Hundred Two Ultimate Gaming Case - Black (No PSU)
Western Digital Caviar Black 500GB SATA-II 32MB Cache - OEM (WD5001AALS)
thanks guys
spec
thanks guys
i dont even know if this is bad or good really
