The pico psu's look lovely, until you get to the small print which says if you're using them 24/7 or if they might get hot, they're only rated for half the nominal wattage. If it's hot and on 24/7, all bets are off.
There are the power supplies silverstone bundle with their cases, but the advice I was always given is to avoid cases with built in power supplies as the built in ones will be rubbish. This puts me off, despite silverstone's excellent name. I'd be interested in information about these, from somewhere which tore it apart and bench tested it. Google is failing me / I'm failing at google here.
Does anyone have any ideas? I'd be quite happy with 200W, as long as it will reliably output its 200W to well within spec, at 50 degrees ambient, for years. I don't think a pico would do.
