Are there going be any waterblocks for TRI-SLI setups ???
Caporegime
27 Nov 2005
Guernsey
Does anyone know if any the waterblock makers like EK are going be able to make waterblocks that will fit in a TRI-SLI setup ????
With any look Tri SLI wont last long enough, but you would just need to buy three water blocks for whatever cards you need them for, i would just give the money to charity though.
surely if you can cool 2 card, you can cool 3, just another block. I think i know what your thinking, the blocks there the hose comes out at right angles to the card (up or down) so you can have it go into the top card from the top, then out downwards and into the second card, then out the bottem of the second into the top of the 3rd, and then off. But i dont see how this would require a different block? Its just 3 blocks.
