Hi All. I have been doing lots of reading (lurking) on these forums and I am thinking about buying either the the Bitfenix Shinobi http://www.overclockers.co.uk/showproduct.php?prodid=CA-019-BX&groupid=701&catid=7&subcat=1850 or the Corsair 300R http://www.overclockers.co.uk/showproduct.php?prodid=CA-063-CS&groupid=701&catid=7&subcat=1489 to build an i5 2500K + HD7850 system. Initially I would only go for a single card setup but if in the future I needed to upgrade would consider adding a second HD7850. So my question is whether you would consider these cases adequate, both in the sense that the cards would fit and that their would be sufficient airflow?
I like the look of both cases but am edging towards the Corsair 300R. Anyone know any reason they wouldn't be suitable?
