are these overclock settings ok?
24 Jan 2007
ok i've got 4.6 stable in IBT with:
multiplier at 46
turbo power limits 200, 200
additional turbo voltage +0.055
CPU PLL Voltage 1.750v
vcore mode to auto
LLC level to 4.
it gives me 1.31v in IBT
is it better to use the additional turbo voltage instead of the offset?
also why on asrock boards the LLC level are backwards? e.g level 1 is the highest, level 5 is the lowest..
ok now i've droped the additional turbo voltage down to +0.027
which gives 1.298v in bios and 1.280v~ under load with IBT.
why is it stable in IBT when using additional turbo voltage to get to 1.280v~ rather than using offset to get to 1.280v~?
