Hi i have run prime and intel burn test for over 24 hrs both on small and large ffts and blend. On full load the temps are 46-49 and idle sits at 24-27. Could i please have some input on what i can do to increase performance more and decrease temps further? And is 27000 a good score? Overclocked specs below:
CPU Frequency 3825.00
FSB Reference Clock 1700.00
CPU Multiplier x9
All spread spectrums disabled
FSB Memory clock Unlinked
FSB Memory ratio Auto
FSB (QDR) - 1700
Mem DDR - 1600
Actual DDR - 1593.7
P1 - Auto
P2- Auto
Memory Timings 9-9-9-28 at 1T
VOLTAGES
Cpu core 1.46250
Cpu FSB 1.500
Memory 2.0
nForce SPP 1.47 as reccomended for 3 GPUs
nForce MCP 1.650 again as reccomended
CPU PLL 1.6
any suggestions and help appreciated guys.
One more thing my memory is supposed to be up to 2000mhz and i currentley have it at 1600, what is the next best step and do i need to alter timings when i adjust the speed?
EVGA 790I SLI F T W DIGITAL M/B / Q6850 EXTREME CPU / X3 BFG 260GTX MAXCORE H2O/OC / 4GB OCZ DDR3 PC3-16000 2000MHz Platinum (9-9-9-28) Dual Channel kit / X2 SAMSUNG 1TB SPINPOINTS / x2 OCZ ssd vertex 60gb in raid0 / Bitspower Mosfet -N/B and
S/B Blocks on EHEIM PUMP WITH 5/8" HOSE AND AQUACOMPUTER 360 RAD / D-TEK FUSION 2 WITH QUAD CORE INSERT ON CPU WITH THERMOCHILL 360 RAD/ LAING DDC 1T (18W) XSPC TOP / TFC 360 RAD AND LAING DDC 1T (18W) XSPC TOP 3/4" TYGON HOSE ON GPUS / ALL CONTROLLED VIA AQUAERO+AQUASTREAM/ TH2GO ON X3 SAMSUNG
CPU Multiplier x9
FSB (QDR) - 1700
Mem DDR - 1600
Actual DDR - 1593.7
P1 - Auto
P2- Auto
VOLTAGES
Cpu core 1.46250
Cpu FSB 1.500
Memory 2.0
CPU PLL 1.6
