Hi everyone, I was wondering if the following laptop specs would be ok to record videos onto a laptop's storage/hard drive?
- Processor: Intel Celeron N4020 Processor - Dual-core - 1.1 GHz / 2.8 GHz - 4 MB cache
- RAM: 4 GB DDR4 (2400 MHz)
- Storage: 64 GB eMMC
- Micro SD card slot (I have a 64GB card which I can use if necessary)
- USB Type-C x 1 - USB 3.1 x 2
- OS: Windows 10S (from what I've read I can upgrade this to Windows 10 Home if necessary, but I'm not sure how much extra storage space this requires)
- HDMI x 1
- 3.5 mm jack
- HD Ready 1366 x 768p
I am not planning to play games on it, I just want to be able to plug in an external webcam and an external mic and record video and audio directly onto the storage or microSD card (using e.g. Logi Capture or OBS). Once I've recorded what I want, I will then transfer to my better PC for editing. Usually the total file size for a full video is between 10-20GB (60-90 mins) but I only need one or maybe two full videos stored at any one time. I may need to upgrade the OS to Windows 10 Home to be able to use OBS/Logi Capture, I'm not sure how much extra space the Home version takes up compared to the 10S version).
Do you think the above specs would be suitable?
- HDMI x 1
- 3.5 mm jack
