- 30 Dec 2011
Hey there, so before assembling everything in the case for my first build I assembled the motherboard, PSU, CPU cooler graphics card and ram outside. When shorting the power on the motherboard, everything worked - monitor recieved signal and all fans went on. Yet after assembling it in the case, nothing would happen - no lights/fans even for the PSU I could not hear the fan. So I tried breadboarding again just now and they all seem to work. I'm assuming maybe I alligned the standoffs wrongly? Can I just check these are pre-installed standoffs in my case:
Top section:
Bottom Section:
Whole inside of case:
Am I right in saying I just align them and use normal mounting screws to screw the motherboard in? This is what I did last time.
Also what else could be wrong if it works outside the case but nothing seems to happen inside?
There's no speaker as a front panel connector that came with my case so I can't check if there are any beeps
Thanks
Top section:
Bottom Section:
Thanks
