Are these temperatures OK?
10 Apr 2008
I just ran speedfan on my new build and I'm scared. These look high to me, but I wouldn't know
System: 1C
CPU: 30C
AUX: 26C
Temp: 55C
Core 0: 37C
Core 1: 39C
Core 2: 36C
Core 3: 39C.
Can you post your build here as not all versions of speedfan can read quad core processors for example, so there temps could be way out...
Looking at your system temp of 1 degree - this is almost certainly the case...
post the version of speedfan you're using too please :-)
Big F
OK, cool. I'm using an eVGA 780i, Q6600, 9800GTX, 4 (2x2)Gb OCZ PC2-8000 RAM, all in an antec 900. The version of speedfan I'm using is the latest one from their website, version 4.34.
I don't know how to figure out load temp, monkey. Sos.
I've just been into the BIOS. It says that my CPU is at 31 celsius, my board is at 24 celsius, and my MCP (whatever that is) is at 43 celsius. I presume these are OK...
Yip they're grand for a quad-core.
And MCH is the northbridge (Memory Channel Hub).
Yeah, the thing that worries me though is that reading of 55 celsius on the 'temp' entry. I'm worried because it has a little flame icon next to it and this makes me think my tower is about to become the towering inferno.
I clicked 'configure' and 'temp' is listed as 'lm75' - whatever that is.
It's probably your graphics card or mosfets.
And you can usually ignore the flames.
I downloaded HWMonitor. It says my GPU is 53. But I don't think that's what the 'temp' was referring to, because I checked it out and LM75 is actually a temperature monitoring device.
Well your graphics card, and possibly your mosfets (depending your board) contain a temp sensor.
