I've got my 3770K overclocked at 4.6GHz (1.2250 CPU core volt) on the MSI Z77 MPower board, with the Intel Liquid Cooler with 2 fan setup (INTEL BXRTS2011LC RTS2011LC)
At idle, Real Temp is reporting between 24 & 31c. Using the blend option in Prime95, I'm seeing a maximum of 72 on average, however when using the High stress level test in IntelBurnTest, I'm seeing temps of up to 98c.
It doesn't feel right to me. I've removed the pump, applied some Arctic Silver 5 thermal paste and re-seated the pump as best I could but I'm still not seeing any improvements in IntelBurnTest.
Has anyone got any suggestions, or is this completely normal?
Here's a link to the CPU ID validation page, in case it helps: http://valid.canardpc.com/2659139
Thanks.
Thanks.
