Are these temps accurate?
28 Jan 2011
OK, after getting the PC running, (huge thanks to OCUK Fourm members) I have been getting temps even BETTER than before with Artic Silver 5 TMC.
Are these trust worthy enough?
RTJ
they look ok i,m running a i5 2500k and i have just looked at my temps and your low nearly the same as mine but my high is lower thean your yours mine is between 25 and 30 but you still ok with them temps :)
Cheers buddy, yeah that was a quick few mins on prime to see roughly if it was fairly low, so thumbs up for the compound then!
RTJ
Ha ha sorry predictive text. Prime 95 its for stressing your cpu to make sure its ok and temps are ok
also meter ment to say never ha ha. Drunk and predictive text dont work
