Ive got a Q6600 on stock speeds cooled by a Ninja Scythe rev B and Noctua NF-S12 1200RPM 120mm fan.
Idle temps are:
BIOS = 50c
nTune = 41c
TAT = 52c
Even though they differ and I'm not sure which one to believe, they all seem too high for idle considering the cooling solution I'm using. I have seen other peoples idle temps using the same solution in the 30's.
Im using Arctic Silver 5 and the unit is secured to mobo properly, room temp is about 21c
Idle temps are:
BIOS = 50c
nTune = 41c
TAT = 52c
