Are these temps ok?
16 Mar 2004
Surrey
3000 Winchester at 2.3ghz
DFI Lanparty nf4
CPU Idle= 35
CPE Load= 50
PWMIC = 45-50
NF4 = 40-47
VCore reads as 1.58 in MBM but lower in BIOS
DRAM reads 2.75 in MBM but 2.7 in BIOS
FSB = 256
Memory at 165 on 133 divider
Yep theyre fine, stock coolers I take it? Cant you crank the mem up any more than 165, change divider to 150 or even 166 if its ddr400 mem or higher
memtest & superpi fail if the memory gets above 215 when the cpu is at stock.
Doesn't seem to like doing 190+ when the cpu is clocked.
CPU cooler is stock
Trying 150 divider - gives 192mhz memory
