Had this PC up and running since around May, but I only was able to overclock it seriously since now. Here are my results:
http://valid.canardpc.com/show_oc.php?id=1324896
These are at stock volts. I know CPUID HM is inaccurate sometimes, but are these temps ok? Using a Fenrir to cool my 965 and it reaches 73c on max load on an hour of Prime, and it seems high to me. It's idling at 37c at the moment. This is my first proper overclocking, my first go was when I was using Ntunes to overclock the FSB on an acer pc
EDIT: Was thinking of replacing the fan on the fenrir and create a push-pull setup, what fan would be good for a CPU cooler?
.EDIT: Was thinking of replacing the fan on the fenrir and create a push-pull setup, what fan would be good for a CPU cooler?
