Are these temps ok?
Caporegime
25 Jul 2003
FR+UK
I'm stress testing the cpu using Prime95, monitoring using Realtemps. It's an i5 overclocked to 4.01GhZ, cooled by a Corsair H50-1.
I realise thats not far in, but the test has been running an hour now and the temps haven't shifted - up or down.
Hmm, to be honest even when it isn't running temps don't seem great, what should I be looking at underload?
What did u use for tim if it's the stuff supplied with it get some quality stuff like mx4.
Check contact between block and processor.
Fit better fan to rad or use 2 in push pull if u can fit them.
Set blk to 200 drop multi to 20 this will let u use slightly lower voltages
The load temps are all important and an i5 760 @ 4Ghz with the above temps, with the system fully stressed, are fine.
As above, what are your volatges and what are your idle temps?
