Are these temps right?
6 Jul 2007
Notts, UK
im running a q6600 at 3.0ghz with a zalman 9700, the temps in coretemp are 56 idle and around 71 load max. The case is an akasa eclipse. Ive also noticed the temps are slightly lower with the panels off.
heard the quads run a bit hotter than the dual core but 56 seems a bit high for idle.
if the temps lower with a side panel off check you're air flow within the case, tidy cables etc.
with the side panel off it drops from 56 to 48. The intake is at the bottom front of the case, behind that are 2hdd's. How could i improve the intake/outtake etc.
change case fans, what you have atm?
what cpu cooler you have btw?
i have the Zalman CNPS9700-LED Aero Flower, and i have the 2 standard 120mm fans that came with the case, what fans would u recommend?
everyone around here seems to like:
scythe, yate loons and noctua
so your choice i suppose, ask around like.
btw check your cpu cooler is seated right and all.
the inside of my case, the heatsink has been changed to face the other way now.
ive just changed the zalman round to face the right way and my temps seem to have dropped now :), to 47 47 42 46 idle, tho i have only just turned my pc on
