Are these the same 120mm fans?
22 Oct 2008
Lisburn, Northern Ireland
Are the 3 fans on the Cooler Master MasterLiquid ML360R RGB Liquid CPU Cooler radiator/cooler the same fans as Cooler Master MasterFan SF360R ARGB 360mm Square Framed Fans? I.e. are they the same 24 LED addressable fans?
I'm building a new PC inside the Phanteks’ MetallicGear NEO Qube Chassis and I want the fans to be all the same type so I can have the RGB setup I want.
I have one set of the Cooler Master MasterFan SF360R ARGB 360mm Square Framed Fans and I'll get another set as well as the 360 AIO too, but I really need to know if they are the same. I do'nt want to have one set of fans on the AIO that can't be programmed the same as the boxed 3 fan sets
