are these timmings rite?
8 Nov 2006
alrite people!
I have some pretty old adata DDR, i ran cpuz and it says the timmings are
2.5/3/3/8 is this rite? i then ran pc wizard exactly the same
ilook at top brand rams and the arnt much diffrent!!
Part Number : Unspecified
Serial Number : Unspecified
Type : DDR-SDRAM PC3200 (200 MHz) - [DDR-400]
Size : 512 MB (2 rows, 4 banks)
Module Buffered : No
Module Registered : No
Module EPP : No
Width : 64-bit
Error Correction Capability : No
Max. Burst Length : 8
Refresh : Reduced (.5x)7.8 µs, Self Refresh
Voltage : SSTL 2.5v
Prefetch Buffer : 2-bit
Manufacture : Week 0 of 2000
Supported Frequencies : 200 MHz
CAS Latency (tCL) : 2.5 clocks @200 MHz
RAS to CAS (tRCD) : 3 clocks @200 MHz
RAS Precharge (tRP) : 3 clocks @200 MHz
Cycle Time (tRAS) : 8 clocks @200 MHz
Memory Controller Information :
Memory Controller : Standard, DIMM
Number of connectors : 4
Max. Module Size : 0 MB
Supported Speed : 70ns, 60ns, 50ns
Supported Voltages : 2.9v
Error Detection Method : 64-bit ECC
Error Correction Capability : Unspecified
Current/Supported Interleave : 1-way/1-way
am i mising something ? is this ram ok?
so would ther be any point in getting some other ram? i was thinking of getting..
Corsair 1GB DDR XMS3200C2PT TwinX (2x512MB) CAS2
but the timmings are pretty much the same!!
No point at all. You may find the corsair overclocked better if you went that route. All depends on what IC's are on the Adata though :)
I got this ram
Corsair 2GB DDR XMS3200PT
And I just changed the settings to 2/3/3/5 from 3/3/3/8 and its working absoltuly fine no extra volts still at 2.7, memtest stable an all, going to start changing one of those 3's to a 2, no 2gb memory achieves 2/2/2/5 but achieves 2/3/2/5 so i'll try that.
what are ic's? im planning on over clocking my cpu and gpu.. what can i clock on this ram?
im pretty much a noob when it comes to overclocking...
