Are UpHere and EZDIY decent?
21 Mar 2016
I have been looking at different options for RBG fans in my new case however i just cant justify paying so much for corsair and cooler master, i saw these and was wondering if anyone has any experience with them? are they bad?
EZDIY-FAB 5-Pack
upHere 3PIN
if not could people make some suggestions.
I was also looking at these. Beware that it says that 'EZDIY-FAB RGB controller is not compatible with other brand's fans.'
OR rather, a third party controller may not be able to speak to the LEDs / provide the expected current / connectors to a non-standard system. See how they ship with a bespoke controller and remote? You may find that it is a plug and play, and often it is. But this would be at your own risk.
Companies like this finance amazon shilling, so look for low-star reviews. A few of them jump out to me RE noise. If you are on a budget then can you make do with a few ARGB lighting strips embedded in the case and some cheap, high quality non-RGB fans? This would be my preference, because you will get the important performance and have a part that you could always sell on later for good money to buy RGB fans. The resale value of these will be non-existent.
As i feared, i dont really want insane lights but it does look like ill be going this direction.
I've got these in my PC: darkFlash CS140 PC Case RGB Fan 140mm AURA SYNC 5V/3pin Cooler Fan PC Quiet Adjust Fans Speed Color Computer Case Cooler RGB Fan
The controller it comes with plugs into my MSI B550 MB and I can control the RGB using MSI Dragon Center. I need to use the supplied remote to vary the fan speed.
