Im currently using powerline adapters to connect to my main PC upstairs. I get roughly 100Mbps, but not consistently.
Im thinking about upgrading my router to AC capable and put a AC wireless adapter in my PC.
Would i likely to get better speeds? Its about 30meters and 2 walls between the router and PC.
Running the correct cable is better than wifi or powerline. IF you can't run a cable THEN you look at the next best option.
Still got one wifi link to eradicate and no idea how to do it at present, but it just streams to the bedroom and is a reasonably reliable 200mbps so not in too much of a rush.
