ARGB advice needed
1 Jun 2020
Hi
I wonder if anyone could help.
My nephew bought a motherboard and cpu bundle and and bought a case separately the problem I have is that the motherboard is b450m-k with no rgb headers and the case is aerocool with 4 rgb fans (6pin)
And I can't figure out how to get them to connect to the motherboard.
I know I would probably need a hub but am unsure witch on i need
Any help is really appreciated
Kind regards
Gary
Aerocool obviously make a fan controller, but it only seems to be available with their RGB fans.
Alternatively you would need several 6pin to 3pin adapter (Aerocool ship with some of their fans, but you may be able to source elsewhere), which you could then use to connect to any rgb controller than supports 3 pin 5V digital RGB.
My basket at Overclockers UK:
Total: £42.46 (includes shipping: £3.48)​
