ARGB + CPU Cooler Advice
from case description.
LED Button - Easily control your fans and have access to several colour modes at the touch of a button once connected your reset switch can be used to switch between the different colour modes
Supports up to 6 fans
The fans should all be daisy chained together and then powered using a SATA power cable.
They are probably custom connectors so its unlikely you will find 2 more fans unless you can get CIT fans. Replacing them will be more than the case is worth. 6 argb fans is going to be about £60
My basket at Overclockers UK:
Total: £62.64 (includes shipping: £8.70)​
You could use the stock paste but I would remove it with some nail varnish remover/white sprit and use some thermal grizzly
Total: £8.73 (includes shipping: £2.74)
If it was me I wouldn't get the thermal grizzly, too expensive for 1 gram, try Noctua for thermal paste. Thermal grizzly seem to be the best at the moment but are you overclocking? If not the Noctua or Arctic Cooling MX4 will do as well. Its just a few tiny degrees difference.
