So. Ive just up graded my pc and case.
I decided to buy and go for 9 cooler master argb fans and water cooling.
I have managed to get a power header for the fans but its sata power. The argb lights are daisy chained and i can cycle the colors however all the same color and not able to do it indavidualy no biggy as they work.
The issue,so far I had to disable bios cpu fan error unable to use bios for fan control,
With that and I guess using sata power the fans are on full and I am unable to adjust then.
Is there any argb/power adaptor that will allow me to adjust every thing using softwear
Sorry if I have the argb and rgb mixed up . Still trying to get my head around the diffrence. So I will explain the connectors.. 3 pin a or rgb head and 4 pin power
Cheers
Cheers
