ARGB questions
15 Mar 2007
Got a motherboard with two jrainbow ports. I want to connect some argb fans to it via a controller. My questions are can anyone recommend a controller (power and argb) and can a jrainbow port handle a controller with 4-6 fans on it ?
Im using the Razer Chroma ARGB controller, it has its own power feed from your PSU which powers all the LEDs you plug into it, it can handle upto 240 LEDs just more than a few, it actually plugs into a USB2 header on the motherboard and you can use Signal RGB, Open RGB or Razer software to control it, its a great piece of kit.
My ARGB hub (headers for 11 ARGB fans) also is powered by a sata plug but for the colours to be set also plugs into the JRainbow headers on my motherboard. I then use OpenRGB to control the lighting rather than have multiple different software to control it. The difference with my hub is that it cost me less than £7 on Amazon.
thanks for the advice here guys. My new kolink case comes with 4 fans and a hub so I’ll use the Jrainbow port
I was thinking of getting the antec case and then buying fans and controller but the new cases are coming with fans and controllers for less money and hassle
If the fans don’t have splitters for their ARGB, you can always buy a https://www.overclockers.co.uk/kolink-argb-1-6-splitter-cable-30cm-cm-00k-kk.html
6 fans is the maximum I’ve ever connected to a port.
As others suggested, a powered hub may be an option, and price wise, not far from the splitter option https://www.overclockers.co.uk/deepcool-sc700-argb-12-port-hub-fg-008-dc.html
There’s also a version of this hub with PWM ports.
Personally I used to control all ARGB with one controller, but fans I prefer to group them according to their position, to fine tune noise/airflow.
I think I don’t need to put more than 6 fans on a case myself especially if the cpu cooler has 1-3 additional fans. A powered hub sounds good to me
The only downside I see with this, as it connects to 1 header on the motherboard, everything you have connected to this hub will be the same pattern (static, rainbow, etc) and the same colour.
That’s the way I used to like my ARGB. Just a tint of teal or cyan. Now I only have solid blue with the minimal area of the Thermaltight Phantom Spirit Evo’s fans very thin line, and the tiny bit on the 4080 TUF. Behind the mesh of the North, barely noticeable.
Drumroll, ARGB fans need power and lighting cables. so with this ARGB 12 port hub is this just for lighting and not power?
Because most full size ATX motherboards will have AIO/CPU/CPU-OPT PWM ports + 4 PWM fan ports for case fans. Considering that most decent motherboards will allow at least 1A per port, and most fans would be 0.2-0.3A (just be aware that the required A to start moving the fan will be higher than the marked A on the fan, so don’t abuse it), you can easily run 3 x front, 3 top, 3 side or bottom and 1 rear, easily, as I expect most people would run each “section” at different rpm. Don’t really need to run one front intake at higher or lower rpm than the other 2 for example, but the rear exhaust would have much less restriction exhausting than the front pulling air through a fine mesh/filter, I would expect the front to be at 10-15% higher rpm.
ARGB, different scenario. Most mid-life AM4 motherboards used to offer one RGB and one ARGB. Latter was 2 ARGB (there’s exceptions, but that was my experience).
I would be happy to connect 6 fans to one ARGB port, but that would be the limit for me. Add to the fans, AIO or CPU Cooler’s ARGB fans, ARGB strips/cables/GPU anti sag bracket… and the list goes on.
The O11d evo, without the front mesh would allow 10 fans, straight away.
The only issue with so many ARGB connected to only one hub (that would only connect to one ARGB port) is that everything connected to it will produce the same light effect. I always liked solid static colours, not an issue for me, but when you start adding a lot of ARG and wants to have different light effects, things tend to get more complicated.
The HUB for ARGB only would allow to have more than “6” fans or any other ARGB safely connected to one ARGB port.
The HUH that offers PWM, would do the same as the ARGB. The hub, unless is some controller like aquacomputer quadro/octo or similar, will only get the signal from the one of the PWM ports from the motherboard, but power will be supplied by the hub. Personally I wouldn’t use a hub for that, as I like to control fans according to their position in the case, and if was the situation where the motherboard doesn’t offer enough PWM ports, like some ITX boards, I would use something like the aquacomputer quadro instead.
Something like the NV7 case does that. You can pretty much connect 12 fans ARGB plus some other gear to their ARGB hub - 2 ARGB channels, that’s all.
Or you can have some hub that isn’t really a hub, is more like a posh splitter, like the “hub” from the Fractal North Mesh. You can install up to 4 fans, if O remember well, and the hub is powered by one PWM fan port of the motherboard. You won’t see a 10-12 PWM hub, without its own power (SATA/MOLEX), unless someone wants to blow up your PWM port.
