I’ve just bought some new componants and I’m having some problems getting them to work. Anyway, here’s the story…
My old system was:
Motherboard = Asus A7V8X-X
Graphics card = Radeon 9800SE
RAM = Generic 512 MB DDR PC333
PSU = Tagan TG480-U01 480W ATX2.0
CPU = Athlon 2600+
Soundcard = Soundblaster Audigy 2 Platinum Pro ZS
I bought :
DFI LanParty UT RDX200CF-DR Crossfire (Socket 939)
AMD Athlon 64 3700+ San Diego (Socket 939)
HIS ATI Radeon X1650 Pro ICEQ Turbo 512MB GDDR3
Arctic Cooling Freezer 64 Pro CPU Cooler
I’m using my old RAM, soundcard and PSU with the new stuff. Everything seemed to go OK when I was installing the new componants. However, when I start the system up the motherboard lights come on and all of the fans start up. However, nothing appears on the monitor and I can hear the fan on the graphics card cycle as it speeds up and slows down. The hard disk chatters but stops after a couple of seconds.
I thought that the PSU might be the problem as the fact that the graphics card fan cycles seems to sggest that it is not receiving enough power however, my dad has measured it with his voltmeter and thinks that it is steady.
Any other ideas?
Thanks.
My old system was:
CPU = Athlon 2600+
I bought :
Any other ideas?
Thanks.
although having said that, once you do get it going, like all DFI boards its an absolute beast at overclocking, the last one i did topped out at 370FSB and my memory would run up to 300mhz in it
The right hand side LED is still blinking on and of, I can't seem to find anything about this in the manual.
