Argh, need a little help with a new build
Ham
Ham
11 Mar 2005
Somerset
Ello people,
I've just 'finished' setting up a new build for my girlfriend.
Everything was going well, until i turned the power on. Everything looked ok, all fans going and such but nothing appeared on-screen. I re-tried this a couple of times and eventually the motherboard splash screen appeared, followed by the 'press delete for set-up' type screen. I pressed delete to check the cpu temperature and such, but it just hung there.
I decided to power off hoping it would work the next time round, but now i'm back to square one with nothing appearing on screen.
I have no idea what its posting as it has no speaker (i've just returned home to steal the one out of my comp).
Heres what i'm using if anyones interested:
MSI K8N Neo4-F SKT939
ATI X800XL
3200+ Winchester
2x512mb Geil Value
Tagan 380w psu
WD Caviar 160gb
Any help/suggestions would be much appreciated.
Cheers :)
Reset CMOS?
Check all the obvious bits, connections and all that.
Check that the Heatsink is on right and that the CPU FAN is inserted right.
Try booting with 1 stick of ram.
If nothings displaying on the screen, check your memory and graphics card are connecting and in place correctly.
All sorted now, the mobo has a built-in 'reset cmos' button, that doesn't appear to do what it should.
Decided to reset it the normal way and now its up and running.
Thanks for the help :)
